I have a Zanussi ZWF 14280W which has a problem with the motor
I have isolated the problem to only occur when the machine is in any setting other than spin.
The element reads 28 ohms when disconnected, and then 27.4 ohms when connected. What should I be expecting here?
Also there is no motor action after the water fills.
The next thing that happens is the symbol for heating up appears in the panel, and when this happens the machine continuously clicks as though the motor is trying to be driven.
I can run the spin cycle with no problem.
My feeling is that the element is only switched in during any cycle that will need to heat the water, and this is the only time that the motor doesn't run.
Problem is that if I disconnect the element the machine obviously checks for an open circuit and then does nothing.
Has anyone seen this before?
I have changed the brushes and the control card.
What else is there?
What else is there?
