Zanussi WJD 1257S
17 Aug 2010
Hi guys hope someone can help me out...
Machine is displaying error code e41, it's leaking out the bottom & the only spin that is working is the 1200rpm. Any ideas what the problem is & is it worth fixing?
It doesn't tie in with all of your symptoms but E41 usually indicates a faulty door lock, the pcb is shot, or there's a break in wiring someplace (unlikely). A door lock shorting out can easily damage the pcb. As for the leakage; you'll just have to try & locate the source. It could be anything from a leaking hose to a hole in the door bellow.
Cheers for that, it's not actually my machine it's the brothers, I'll pass on the info, thanks again!
