I recently went on holiday and, before I went, switched off the water supply. The washer dryer was left plugged in and with the door open but not in use and with no water supply (afaik, turning off the stopcock would stop the water supply to the washing machine too?). When I got home, there was water all over the kitchen floor (this is before I had switched the water back on). I presumed it was from the freezer and went and switched the water supply back on.
A day later, I have gone to use the washing machine and found that the drum has water in it (up to the level of the door) so presumably this is where all the water came from. What could have caused this and how could it have happened when the water supply was switched off and the machine wasn't in use?
I've got cover for the washer/dryer and also separate cover for any plumbing problems (ie problems with the pipes rather than with appliances). However, I don't know which it is - or if it's just a routine maintenance issue that I should know how to fix myself (as I won't be covered if it's just a routine issue that I should have fixed myself).
