House - Heat Exchangers with 2 way Honeywell Zone Valves (about 18 years old).
On one exchanger the hot water stops flowing after the specified temp is reached.....so it appears.f
If I turn up the thermostat then no flow (cold pipe into exchanger).
If I turn the heat off then on again then no flow (cold pipe into exchanger).
If I turn off the heat then I get resistance from the valve lever.
If I rock the lever back and forth twice then the waters starts to flow.
What part of the valve would be faulty do you think?
Is there any other troubleshooting I need to do for more info?
