Gentlemen,
I have a Multi Fuel boiler and an Oil Fired Boiler each able to run the CH and HW. (Free logs so the Multi makes sense)
When the Multi gets hot it inhibits the Oil Boiler and takes over the system via it's own Pump and 2 off Zone Valves.
It's worked fine for years but lately when the Multi needs to dump heat it's Pump starts up, the 2 off Zones are energised but the water fails to circulate properly. Temperature slowly rises downstream of the Pump and the Zone into the CH circuit but the return loop does not get hot.
The Pump sounds OK and I've manually opened the second Zone and indeed laterally taken the motor off it and it moves fine.
Question is, do Zone valves choke or is it more likely to be the Pump?
Pump is only 2/3 years old. I've tried it at all it's speeds - no difference.
