The following regulation:
Heating zones will often be divided to cover ‘living’ and ‘sleeping’ areas or upstairs and downstairs. Both zones must have heating control through a thermostat and individual TRVs.
All radiators must be fitted with a TRV except those in bathrooms or rooms with a room thermostat. The same applies within existing properties where it is good practice to install TRVs when replacing a boiler has drained down a system.
The Domestic Building Services Compliance Guide references the main requirements for Boiler interlock and time and temperature controls.
I get, for a boiler swaps, zoning is not required, but the above is a little confusing.
Building Regulation requirements: Zone Controls
The Building Regulations require that all new systems in non-open plan domestic dwellings with a total floor area > 150m2 should have at least two separate heating zones, with one zone covering the ‘living area’.Heating zones will often be divided to cover ‘living’ and ‘sleeping’ areas or upstairs and downstairs. Both zones must have heating control through a thermostat and individual TRVs.
When do the Building Regulations apply?
- Every time a home is built.
- Every time a home has an extension or change of use.
- Every time more than one individual component, such as a boiler, is replaced in a heating system.
