S
Shutpa
I've just discovered an icon on my desktop called zoom mode. I have no idea what it is but when I click on it, I get the message, "Zoom Mode cant be found". Can anyone enlighten me as to what it could be?
An awful lot, viz:Could it be that you had some sort of tool to magnify text etc on your desktop in the past?
Try right clicking icon and select properties. What does it say in the target window?
Another wild guess, did you ever have/or still have a Zoom dial up modem?
I had assumed that you were using Windows XP. Network Places should be on the Start menu probably under My Computer Vista
Are you actually using the dial up modem for your internet connection or do you have broadband and still have the modem installed? Yes we have dial-up broadband.
If using dial up you should find Phone/Modem icon in control panel double clicking on that will give you information - if memory serves, its been a long time since I used dial upTried to access this but a new window appeared asking for an Area Code and a Carrier Code
How can I get an internet connection that is always on?
Ahh...I have only had a little experience of Vista (most of it bad) so unable to comment on any set up
I am a little confused here you can either have a broadband connection which in most cases always on or a Dial up connection which dials your ISP number to make a connection (and you pay the cost of a local telephone call) - how do you connect?
That allows you to set up a new connection
I believe most broadband connections are always on (not all though) so this suggests yours is a dial up system
