I'm trying to understand the control logic of the boiler to figure out my problem.
System is a loft mounted 24i - a complete new system replacing warm-air. 13 Rads all with TRV's. Kept old hot tank with coil, with a 3 way valve in loft. Timer and 3-way are honeywell. System pressure is 2 bar (is that too high?).
Hot water comes on morning, noon and night. CH is on constant, with a programmable thermostat downstairs which i use to control timing and temp for CH.
Problem:
Quite often in the evening, despite the thermostat being on - the rads don't come on (pump not running). Then after perhapps an hour or so, they come on. This has been happening since install, I assumed that somehow it decided the house was up to temp and didn't need to come on. But last night, the house was freezing, stat was on - but still no heating. So last night I simply switched the hot water switch on and off - and hay presto whole system fires up.
Been thinking about this a little more, and thought it might be connected with when the water tank is being heated - as last night we didn't have a bath or do the washing up(!) - therefore it wouldn't of had to spend much time heating the tank and would of gone off early. (The tank mounted thermostat is set to 50'c)
I need to study it a bit more over the next few days to understand the scenarios when it doesn't come on, but was wondering if theres a problem or installation error.
Thanks,
Eliot.
Problem:
Thanks,
Eliot.
