Hi guys looking for a bit of advice to diagnose a problem. I've got a fully pumped, 3 port valve central heating system controlled by a Danfloss CP715. I have thermostats on both the hot water tank and living room (basically it's a fairly standard install).
It's worked fine for years but just recently it's developed a problem where the heating and hot water will both come as scheduled (auto setting, both HW and CH red lights on). The hot water and rads both heat up but when the hot water tank reaches the set temperature the central heating will also go off even if the room temperature is well below the thermostat setting (both HW and CW red lights still on).
The bizarre thing is this only happens intermittently (say every couple of weeks) and I can always fix it by killing the mains to the control unit and then turning it on again. When I do that it the pump immediately fires up and the rads get warm again until the room thermostat turns it off.
I'm sure it's not the thermostat as that's just a switch and it works fine. I suspect it's a dodgy controller, but could it be the three way valve. I'm not familiar with how the internal logic of these controllers work, and I don't understand why a mains reset fixes it. Any ideas - I don't want to replace the controller if there is nothing wrong with it.
Thanks for any help,
Mike
Mike
