Recently my 28CDi has only recognised the demand for hot water if two taps are turned on. Having trawled the archives this sounds like a diverter diaphram going weak/perished, so I've ordered one.
I've just had a closer look at the plunger shaft and microswitch as the hot taps are turned on and off, and it seems to me like the problem might not be what I first thought. The shaft has a circular piece of plastic on the end, and the microswitch is slightly off centre of this circle. The piece of plastic seems to be on a spherical joint so that the moment it touches the microswitch, it deflects, until the shaft is so far out that the microswitch is finally pushed.
Is this normal operation, or should the plastic circle be rigidly mounted to the end of the actuator shaft?
Gary
Gary
