G
Goldspoon
Have a couple of questions I just want to confirm answers to... hope somebody can answer (yes/no is fine to save your time but if no any thoughts appreciated
Combi boiler: the pressure as indicated by the guage on the boiler (clock type face or digital display) only indicates the pressure of the primary heating circuit (hence using the filling loop to boost this circuit). Am I correct?
Combi boiler: Hot water is at a pressure dictated by the boiler and there is usually no way to see on any guage what this pressure is - it is usually mains pressure reduced down by the boiler so the boiler has chance to heat it before it passes on it's way to outlets...
Combi boiler: Cold water is at mains pressure not reduced down.
Unvented cylinder: the pressure as indicated by the guage on the cylinder (clock type face on the one I know) indicates the pressure of the primary heating circuit (hence using the filling loop to boost this circuit). Am I correct?
Unvented cylinder: the hot water in the cylinder (bath water etc.) is only under pressure doe to this cylinder being mains fed and once again there is usually no guage to check what this pressure is?
I know that these are fairly basic questions but I am striving to learn more about CH systems in particular
