Earlier this week one morning we got up to no heating and on checking the water pressure on the boiler it was at 0. We opened the taps to refill it up to approx 1.2 but within an hour it had all gone again. An engineer came out and said he had cleared some gunk out of the system which may have been causing the pressure relief valve to stick, but it did not fix the problem. A second engineer came out and bled all the radiators and said there was a lot of air in the system but still the problem has persisted. Literally every hour we are having to refill the system. The latest engineer has suggested that there must be a leak under the floors in the pipework somewhere. This has been going on for 5 days now so I am fairly sure that the leak cannot be upstairs otherwise we would have noticed it coming through the ceiling or something by now. Assuming therefore it is downstairs, the engineer did say he was surprised that, given the volume of water that must have leaked out by now, that we would have probably noticed a damp smell by now, but we haven't.
I have today lifted a few flooboards up in various rooms downstairs, no evidence so far of any leaks. There is a lot of brickwork under the floors partitioning the rooms off but there are holes in between these bricks so I am sure that water would have seeped around a bit once down there.
As far as the boiler is concerned there is no evidence of any water coming out of the pressure relief valve. However as a test somebody advised isolating the boiler at the return and flow valves and if it still dropped then it would be the boiler, else it would be the pipework. I did this and sure enough it did drop, however could somebody check the image attached to confirm that I shut off the correct valves - I turned the valves numbered 1 and 5 off - this is CH flow and CH return as labelled shown by the arrow.
The engineer also did this test a couple of days ago and said that when he did it the boiler did start to leak (not enough to have explained the amount it drops by), but he is going to order a new part to fix that particular leak. It did not leak when I did the test, although occasionally when I refill the system it does drip a little bit.
I am sure it must be a leak as opposed to the boiler leaking, but then the test I did seems to indicate the opposite?
Also we have refilled the system, turned the thermostat right down so it does not kick in and still it drops, which to me can't be the boiler as it's not even firing up to burn it off or anything!
Any help gratefully received - in the attached image I shut off 1 and 5 via the valves circled. The pressure then continued to drop. Is this a valid test? (Click on the image to make it bigger).
The boiler is a Vaillant Ecotec 831 Plus.
Thanks in advance for any advice.
