Core drill for waste pipe
14 Mar 2007
Yorkshire
I'm planning on buying a core drill to pass a 40mm waste pipe through our medium density block walls. Should I get a 40mm or 42mm drill core?
I can get hold of a 40mm one much cheaper than a 42mm for some reason but not sure if there would be enough play.
screwfix armeg range do a 42 mm core. well priced too
i chop away the brick a nats on the outside so the collar of the fitting fits flush in the brick work.
The 40mm is cheaper cos its too small! The OD of the pipe is 42mm but as above the hole needs to be a bit bigger to accomodate the fitting, personally I use a 50mm bit most of the time!
Personally I only ever core for flues. Stitch for anything big and good old hammer and bolster for waste. :roll:
get a 50mm, will make your life much easier, 4 mm is still not a lot to fill up after install
