Hi guys thanks for your time.
Ive just core drilled a hole for my kitchen sink waste stupidly my holes dont line up perfect enough to fit a 40mm waste however a 32mm will fit through.
Are there any regs against or repocutions to running my kitchen waste in 40mm solvent to the cored hole then 40mm to 32mm on the 350mm section which goes through the wall? Will there be much slow up on the drainage?
If so I'll have to try get in with hammer and chisel open the hole a bit more sigh.
Thanks.
Chris
Thanks.
Chris
