No Hot Water
14 Jan 2003
On Christmas Eve I found I had no hot water, as a temporary measure I have been heating water using the immersion on the hot water cylinder.
My system is gravity fed hot water with pumped central heating from a Potterton Flamingo 40 boiler.
On closer inspection I found that the pipe from the boiler was carring hot water to the cylinder, but the return from the bottom of the cylinder to the boiler was cold.
I drained the system and added a cleanser (from Wickes) which I left in the system for a week. I then drained the system again and added an inhibitor.
But still I am getting this blockage which seems to be in the coil of the hot water cylinder or the return to the boiler.
The only way I have been able to shift this blockage is by removing the thermostat in the boiler and letting the water heat up until it boils over into the header tank. This water pressure pushes the water from the boiler through the coil and I then have hot water (to the taps) for a day or two and then it is back to square one.
My next plan of action for the weekend will be to remove the connections to the top and bottom of the coil and see if I can "rod" the blockage out of the system, what do you think?
I only found this web site today so any comments about any of the above would be greatly appreciated.
Cheers
Rocket
I am not a plumber or heating engineer but that sounds risky to me, incase you damage the coil, as it is designed to carry water could you not secure a large diameter hose on at the bottom going to waste, and put your regular hose (secured) at the top and turn the water up slowly, but do leave it for some time?
I had a similar problem last weekend and I removed the cylinder and blasted the blockage out with a hose until the water ran clear...seems to have worked OK so far!
