Hi. Can anyone help with my query?
Currently I have a standard wired Drayton RTS room thermostat in the hallway and I wish to replace it with one of the new wireless types. The reason is because the location of the stat at the moment gets the house warm, but not the living room. This because it always switches the heating off before the radiator in that room (last on circuit) gets hot enough to provide sufficient heat. I have looked at moving the stat into the living room but it seems tricky with running the wiring. So I thought that a wireless stat might be the best solution, as I can put the controller module in the optimum position in the room without the hassle.
Now here’s my problem. My Drayton stat just works from 3 wires- Live & Neutral and a switch line or call for heat. Now I have looked at several makes of wireless thermostats - Honeywell, Siemens, Drayton - and it seems that usually the receiver module needs to be connected up with 4 or more wires - a separate Live and Neutral and wires for the switch feeds.
Is it possible that I can just replace the Drayton stat with a wireless type and connect it up using the existing 3 wires or do I have to completely reinstall with additional wiring?
The boiler we have is a Potterton Kingfisher 2. Thanks. Steve
