extension costing
6 Jan 2009
Gwent
could any one out there give me a ballpark figure how much a single storey 30'x10' extension to the side of my house might cost. nothing fancy 3 walls and a roof. maybe 2 windows.
Assume £900-£1000 per m2 depending on finishes etc so 28K for single storey and you'll be about right. If 2 storeys double it. Add around £1500-2000 for fees etc if using a technician or cheap architect to get planning and regs drawings done, maybe a bit more if an engineer is required.
If its any help, just doing a 4.3 metre x 4.3 metre single storey extension with a hip end roof, only thing i have not done myself is brickwork,
( i know my limitations !) so far this has cost us circa £9.7k, started off with a budget of £12k
Three walls, three windows and a door
Did my own drawings, with some much aprreciated help from SHYTALKZ on here, with regards to the beam calcs.
Nearly done apart from plastering, fascias and soffits.
Expecting to use rest of pot on all the silly bits, radiators, flooring etc etc
As per Freddie really.
Although very noble, Tufty's advice is of no use if you intend using a builder or building company to carry out the work.
