Hi, for my living room floor theres about a 4-6 inch concrete base and on top of that theres about 20mm with some kind of screed, bitumen or asphalt hard surface not sure which to look at it is a hard black surface.
Anyway the problem is around the perimeter of the room the there are cracks in the black surface and some parts have broken away these range inwards from the wall from 20mm-120mm. i've also discovered in places that theres a small gap of about 5 mm between concrete base and the wall and a few small bits of concrete broken off.
I'm just wondering the bast way to go about repairing this so it water proof and whats materials to use.
Heres what I was thinking of doing:
- For the concrete base - Fill with mortar the 5 mm gap between the base and the wall, also fill in the small areas that have broken off.
- Prime the areas that need repair with with Bitumen primer making sure that I come up above the existing Damp Proof Coarse in the wall http://www.toolstation.com/shop/Str...ls/Bituminous+Primer+1+Ltr/d210/sd2809/p15467
- coat the primed area with Cromaprufe http://www.toolstation.com/shop/Str...aterseals/Cromaprufe+5+Ltr/d210/sd2809/p10290
- Then once all that has set, level the areas with a floor leveling compound http://www.wickes.co.uk/Deep-Base-Levelling-Compound/invt/154050
Will this be adequate for repairing the floor and making sure the areas as damp proofed?
Is the a better way of doing this... I know the best way to make sue its 100% damp proof would be to dig up all the floor put in a DPM and pour with concrete. But I think this might be over kill for the small areas around the room. I'm wanting more of a repair solution if thats possible.
heres a diagram
although the flooring in this photo still has some plaster on it is should give you an Idea of what I'm talking about.
heres a diagram
