stud wall insulation
31 Aug 2003
I would like to insulate a studded wall and was wondering if B&Q or similar sold anything in rolls ( i.e similar to loft insulation ).
Has anyone any recommendations.
Thanks :D
Aaaargh, right answer, wrong question. SORRY :oops: :oops: :oops:
I'm just trying to smooth out the ceiling where a brick dividing wall has been removed (bloody dusty job).
Her indoors informs me that the rad was removed from this wall, the pipes were cut and capped below ground level and then just creted over(this was in a summer).
Before the heating was required the supply pipes to this rad were cut off at source and the ends that were still on the system were capped off.
No doubt I will find the pipe work when I try to put in some new sockets
You might find it easier to use Rockwall Insulation Slab,they normally come with 50mm thickness and you can double it if you're using 100mm timber.I know Wickes do sell them.
Would you be able to use loft insulation or should it just be left for what it says :roll: :- loft insulation
Yes,you can. I just find the slab is easier to handle & cut,the choice is yours.
Thanks, i have decided to go for the slab as suggested looks easier to install, thanks again
