I Have been reading the posts on spurs and general info on them on other websites, they say that a spur that is too long can be dangerous!! But cannot find out how long is too long! One of the posts on here suggests using 4mm cable instead of 2.5mm if the spur is going to be very long, is this correct?????
I am planning on running a spur as my earlier post says, from an existing (suitable) socket under the wood flooring to a FCU. In all it will probably be about a 3m run, is this too long? If not, should I use 2.5mm or as the other post suggested 4mm cable????
