Repairing wall after removing skirting boards
4 May 2006
Warwickshire
I have just removed all my skirting boards from downstairs, prior to fitting laminate flooring.
Now that the skirting has been removed, there is a gap where the plaster is missing, about the same height as the skirting boards were.
As I will be fitting the new skirting with "No Nails", it needs a surface to adhere the new skirting to, therefore effectively extending the plaster downwards to the floor.
My question is, what can I use to fill the gap??
What is the depth of the gap?
If the gap will be covered entirely by new skirting, why don't you simply fill it with sand/cement?
sanjay
I'm no builder, so I may be wrong, but I thought they left this gap between plaster board and floor on purpose on the outer walls, to stop damp travelling up the wall???? When we had a damp proof course and they removed all the old plaster board etc.... they left this gap on purpose. But like I said Im no expert, so I apologise If Im wrong.
bridging the dpc...not good :wink:
