Hi All,
I'm stumped on this one-maybe to much beer while the cup's on....
I've just wired in a new consumer unit and the lights keep tripping the RCD ,....It has been wired to it's own 6A MCB but it kept on tripping the RCD.
Further investigation showed that the the only 2 way lit up the tester(screwdriver) on the light switch screws ,....Checked further to find that the voltage to earth is 55v~ and when operating the switch it is 74v~
The wiring has confused me totally as the 1st light switch is one which controls a two way one side and a straightforward light. On the 2 way there is a twin & earth and a single red. The single red connected to the top terminal of the 2 way from here a jumper to the standard single light switch. On the bottom terminals the twin is connected 2 the terminals and the earth to the casing on the 2 way and a single cable to the single light switch.
The 2nd 2 way light switch is wired exactly as the first one,.... At the rose it appears to be a loop in system with the 75 & 50 showing up again when the 2 way is operated to the 2 "off" positions.
I did check and it was working fine (2 way)on the old board which was a rewireable wylex one. The wiring I have since been told has been done by the "electricity board" originally.
What have I missed!!!!- I know it's something that is right in front of me but I just can't see it!!!
Any help will be most appreciated- The client is now without lights tonite(said the telly would do!!!)-
Thanks in advance,.....
