Smeg dishwasher
1 Jan 2007
London
My Smeg dishwasher runs for a few minutes and then beeps and stops. Programme does not run for long enough to open dishwasher tablet compartment. Have tried cleaning filters. Any other suggestions?
Check the instruction manual, Smeg often use the program lights to give an error code.
Suspect the evacuation pump. Is there more water at the bottom than usual?
Which model no. is it?
Cheers, Simes.
Model DI612C. The indicator lights indicate "safety level", which apparently means the system which limits the water level inside the dishwasher has been tripped. Not obviously any extra water in machine. Switched off and restarted but didn't help. Can I do anything to the evacuation pump or any other suggestions?
Thanks.
Have you had problems with the electricity supply? Flickering lights or even power cuts?
It appears that your machines pcb has defaulted to factory settings and needs to be reset.
Not been aware of any power failure. Can we reset the dishwasher our selves? We did try switching off at the socket after the problem began but it made no difference. Thanks.
I'm guessing that you're getting either an E2 or an E9 error code.
If so, open the door, switch it off, switch it on and immediately press the program button 4 times within 3 seconds. (Don't wait for any lights when you switch it on, just quickly press the button 4 times).
The two end lights should light up. Press the program button and one of the lights should go off.
Switch it off for about 20 seconds, switch it on, switch it off for about 20 seconds, switch it on and it should be reset.
If resetting doesn't cure it, check that the base isn't flooded and the anti flood device activated.
If you're getting any other error code don't do the reset, just post the lights that are flashing, 1 being left and 5 being right.
It looks like an E2 code. The 2nd light flashes and the 5th light is on. Nothing changed when we followed the instructions and there is no obvious water in the machine when you open the door. Any other ideas?
Thanks.
Check for water in the base of the machine, not the tub.
Drain the water from the base, if there is any, and the machine will reset itself.
If there's no water follow the reset procedure as previously described.
You must get the two end lights lit first before you can carry out the rest of the reset procedure.
If you can't get the two end lights lit then it's possibly a faulty pcb. At this point I'd recommend getting an engineer in to diagnose further. Parts can be quite expensive.
Engineer called this morning. Faulty PCB. £120 + VAT + call out charge so not worth doing even though machine is only 15 months old.
Thanks for all your help!
:lol: Many thanks Sleepyhead, this worked for me and my dishwasher is now up and running again. Thanks again.
For the advice above.
I had a problem with my 710 and after soaking up 2-3 inches of water that were in the tub at the bottom and performing the reset, its now working!
Eddseven :D
I've just had a problem with a DWI45.1 where there were no indicator lights and the heating element was permanently on!! I was quoted £213 +VAT to fix so thought that I'd try the reset sequence above and hey presto it worked.
Ian
Thank you Sleepyhead. I followed your instructions and they worked.
Thanks again
Richmok
I too am having trouble with a DI612C and an E2 error code.
Unfortunately the reset method does not work with me.
Nothing happens when I try pressing the button 4 times using the correct method above.
However I can hold down the program button and it ends its cycle and I can start a new one but exactly the same thing happens.
I have checked the tray underneath for water and it's all dry.
It appears to filling and draining fine.
Does this sound like a pcb fault?
This is exactly what happens:
It fills fine and rinses for a while then drains fine.
Fills again rinses for a while again then as its draining the second time it beeps 3 times and the code appears although it finishes draining still then sits quiet with the code showing.
Any ideas?
Thanks, Magnus.
