History:
since moving into the house in summer it was clear the previous owners use the thermostat as a switch (heating was ‘on’ on the programmer and '0c' on the stat), when the cold came it was clear the thermostat didnt perform right (too much hysteresis) but i figured it was probably due to it been previously used as a switch, now i suspect its because it was wired wrong. today i was passing screwfix (its quite far from my house so i dont normally pass it) so i popped in and got a new thermostat (this one).
doing the change:
Now Ive had a look at the old wiring (yes I should have done that before buying a new one!) and it looks like this:
diagram inside:
measuring things i get: (contacts are labeled 1-4 going top to bottom)
4-3: (neutral to earth): 0v
4-2: (neutral to other end of heater): 250V (stat in any position!)
4-1: (neutral to Live): 250V or 0v when stat turned down!!!!
so im sure 1&2 are the wrong way round? anybody agree or disagree?
I suspect if i change these round it will work a lot better, but i have bought a new one and it looks better so i think i will put it on!
this is the diagram:
so i recon i wire it:
1: red (or yelow if the above assumption of it been wired wrong is wrong!)
2: yelow (or red if the above assumption of it been wired wrong is wrong!)
3: not connected (it does state no earth required in the instructions and I checked with my multimeter and, as the diagram indicates, 3 does connect to 1 when the stat it turned ‘low’)
4: Blue
any comments before I change it over?
(ps sorry pictures are from phone in low artificial light)
doing the change:
diagram inside:
4: Blue
