Frame Fixings
20 Jul 2006
Kent
I am installing 2 new windows, 2400 x 1200 this weekend, and wonder how many frame fixings I should use each side, and top and bottom?
I'm assuming the 1200 is the height, if so, then 4 fixings on each side and not top & bottom
Thanks. Yes the 1200 is the height.
Will the window 'wobble' with nothing top and bottom with the 2400mm width?
Swiss
Not once the d/g glass unit is in although you can if you want to but may hit the metal lintel or rod etc, unless it is a one unit of glass(?) I sometime bed the bottom cill on rapid sand/cement if the bottom isn't level.
