I will also change the DHW Stuffing Nut, as I have leak/weep from this.
I assume you just replace nut (which has bit of silicone grease inside) & push DHW diaphragm pin through (??).
Nothing more.
Just wondering as I think there is mains pressure on other side inside valve, so surprised this is enough to seal, pin pushed through plastic seal in the nut.
From what I can see just those 2 parts in DHW valve to replace from vokera T0019 service kit (see pic below).
