The final step will be to have a professional electrician install a new consumer unit and test my work.
In all of your planning you have forgotten that this will be your first step, not the last.
Electricians who are members of the Competent Person Scheme are permitted to notify works that they have done themselves. They just cannot do the final connect and test, unless they lie on all of the documentation.
You have two choices under the current LAW.
1. Find yourself a registered electrician. There is a website with them all on
http://www.electricalcompetentperson.co.uk
Find one who will let you do most of the grunt work, but what cables etc you install will need to be under his direction. He/she could then carry out the final testing, certification and notification to the local authority.
2. Raise a building notice with your local authority and state that you are doing your own electrics. The LABC will want to inspect the work at various stages and will expect you to be able to design, install and test the work to BS7671. So yopu'll need to bone up on that - that document has all of the answers re max sizes for radial and ring circuits. and everything else - its a fascinating read.
There's more info on your options at
//www.diynot.com/wiki/Electrics:part_p:DIY-Electrical-Work-and-the-Law[/QUOTE]
