Hi all,
I want to run electric to two sheds. The sheds are located about 15 metres from the main house and are located together (probably a couple of metres between them).
I wanted to seek advice from those 'in the trade' as to the best way to do this. I do have a plan but need to make sure that it's ok.
Firstly, I need to point out that I'm a competent "DIY'er". I have done work on electrics before but I've never run power outside.
The house has an old 6mm twin/earth cable that runs outside (the previous owner used for a hot tub). This goes back to it's own breaker on the distribution board and also runs through a large 32 amp switch before going outside.
When we moved in this cable was just coiled up outside. I needed an outdoor socket so I buried the cable around the bottom of the house and connected it to an outdoor socket.
My plan was to 'spur' off this socket with 4mm armoured cable clipped along the side of the house (probably run straight up to the top of the house and then along under the eaves), run it around to the side of the house, down to the base of the fence and then run it through maybe some 'milk pipe' (basically 1" diameter stainless pipe) along the bottom of the fence to the first shed. Then take it to a distribution board in the first shed and have breakers for the lights/sockets in the first shed. And breakers for the lights/sockets in the second shed.
To connect the second shed I was thinking of running a bit of galvanised trunking at high level between the two sheds and then tie wrapping armoured cable to it?
Also worth noting that this is our 'forever' house but if we do sell it I would simply disconnect the 6mm cable from the distribution board and leave it to the new owners to reconnect if they wanted.
So... advice/questions....
I realise that you shouldn't 'spur' from what is technically a spur (ie. the outside socket that comes from the 6mm cable) but I'm thinking that because the outside socket is very occasional use (mowing the lawn every week) and it's being fed by a 6mm cable then it should be ok ?? (thoughts?)
Am I allowed to simply 'clip' or 'cleat' the armoured cable to the outside brick of my house? Or does it have to run inside conduit or some such??
Is running the cable through conduit/milk pipe at the bottom of the fence the way to go or should I look to bury it? If so, how deep and can I just bury the armoured cable as is? Or does it still need to run inside something?? (I'm wondering whether rodents would nibble through it etc)??
To connect both sheds is it sufficient to have one distribution board and feed the two sheds? Or would they need a distribution board each??
Is it ok to run the armoured cable at high level between the two sheds? Or would it need to be buried or run inside conduit etc??
I am aware that an easy answer to these questions is to get a "qualified electrician" but I would like to do this work myself. I am very dilligent and capable and my work tends to be a lot neater than a lot of 'proper' tradesmen so this certainly won't be a 'hash job'. I just want to get advice on *how* to achieve it in the best possible way?
A big thank you for any help you can give me on this.
Cheers
Cheers
