S
spacedmonkeys
As per topic, have had builders in to do rework on the layout of the downstairs in our house.
They knocked down partition wall and rebuilt further along.
While doing this they set off the house alarm due to the PIR sensors being mounted on this wall, I am guessing some sort of tamper.
They then put the PIRs back, pointing same way as previously, but since then the red light on the PIR sensor continues to blink. There are three lights on the sensor, green, amber and red. They appear to work as normal when walking around the house...ie amber green and red light up when they detect a presence. However if you leave the room the red light continues to blink constantly.
I attempted a 'reset' using the intellisense panel but this doesnt clear the red lights...
Also attempted to do a 'walk test' however when doing this it doesnt seem to work as intended, it shows red led's on the panel regarding to the 2 moved sensors.
When setting and unsetting the alarm using the panel, the 2 moved sensors also show red led on the panel as if they have been triggered during alarm active.
Any help on how to get the PIR's back to normal, and what was/is causing the issue?
Many thanks in advance
