If you can get to the hot bath feed from the loft fit it up there then![]()
Are you sure the new ball valve has been fitted correctly at the correct water level and is definetly shutting off?
You can check by trying to stop them each in turn. You should find you can stop the hot easily, but not mains cold.
I have tried to turn off each individual cold feed today buthe hot water nothing stops the water.
Only the old sure fire way off running the hot water tap (to reduce the water level in the storage tank) will stop it.
What next guys ?
What next guys ?
Did you turn the cold to the bath off![]()
It is mains water to the bath and You have a stopcock/valve to turn it off
The bath shower mixer is likley but a photo is helpfull, It should'nt have a cold watermain feed as its a mixer, is it one with two headds for the bath & a large knob for the shower temp. If u have an electric shower why do u need the bath shower mixer.
if its just a bath deck mixer cant see it backflowing into attic unless the outlet was blocked
