C
calumr135
okay, so what you are saying is that is each circuit has its own fuse in the panel in my case ressetable fuses, the bottom aux terminals for the detectors can handle 1250ma/800ma, and the bell and siren teminals are rated to 1 amp.
i would only be overloading the panel slightly if i connected the bellbox holdoff and speaker wires to the bottom aux terminals if the temperature surrounding the panel was 40c which is roasting, the panel is in the cupboard under the stairs which is pretty cold, put it this way a lot cooler than 40c lol.
ps everything is wired correctly and the only thing connected to the aux circuit is the power the 4 detectors which draw 54ma which is nothing. the bellbox and speaker are connected correctly to there correct terminals [eg speaker connected to siren terminal]
the panel has been here for 20 years or so and has rarely ever caused false alarms and i have changed the battery every 5 years, the panel must be okay if its lasted this long.
