Hightowermark said:So whats better, solder joints or using solder on its own?
you mean pre-soldered (known as yorkshire) vs. plain (end feed)?
A plumber will use end feed all the time. Yorkshire are supposed to be easier, but speaking here as a diyer, in my opinion the end feed are easier. particularly with 22mm pipe. A large part of this is that cheap blow torches are very hard to control, and it's too easy to get the joint too hot, or unevenly heated, and have most the solder run out. With end feed you can take your time and get the heat just right before applying solder.
End feed is also much cheaper.
