Ok, cheers. Just thought it was worth double checking. Out of interest, is there any point in getting a thermostat fitted to the cylinder, or based on the age of the system would I be aswell just overhauling the whole lot?
If you're looking to change to unvented and do away with the tank in the attic, you'd need to check the incoming mains had adequate pressure and flow, get controls upgraded and find a route for a discharge pipe.
A straight swap for your vented cylinder would be something like this
http://www.screwfix.com/p/rm-1200-x-450-indirect-cylinder/86775
Which is a bigger size to give more hot water for multiple showers or baths (the existing cylinder is probably 450x900)
Edit: post race with JohnD.
Hi mate, it says indirect on the sticker on the front.are we sure thats not a direct cylinder
