I need to leave some dead legs on feed and return pipes from my boiler. This is because underfloor heating will be connected at a later date.
Should I just fit 22mm stop ends on my dead legs (the pipes terminate below the boiler and are not at high points)?
Is there a better solution so I do not have to drain and refill the boiler when the underfloor heating is retro fitted later on?
