Bamber gaspipe said:ollski said:[
Who told you that?, there is no such duty on you at all.
Whatever , you seem to have been told something that neither myself or anyone else I have spoken to has ever heard. You have a duty of care in that you are not allowed to ignore a potential safety issue, but you certainly don't have a responsibility to check something you are not working on or inspecting with no indications of a safety fault.
The reason I am here though is to pick up information I didn't know so by all means enlighten me.
Your first duty when attending a situation regarding gas is to establish there is no leak before you start..These are NOT the Regs, I never said that they were, but I would have thought that you of all people Ollski would agree that this was neccesary..if not let`s just say you finish doing whatever on your gas appliance.You then carry out your test & get a drop.Was it there before you started or is it down to work you have just carried out?....Bit of a nightmare if you have just installed a length of pipe to an existing gas run & find that you have to start capping off appliances, or pipework you have just installed to locate the leak.
If you do not carry out a tightness test after servicing a boiler & just spray the joint with LDF how do you know that you haven`t left a gas leak on fire, cooker,water heater or any other appliance?..are you or the rest of the engineers telling me it`s not your problem?...I think it is.... & if Transco are called to a completely unrelated incided because there is a gas leak & you were THE LAST ENGINEER AT THAT PROPERTY you will be Riddor`ed & rightly so.
To Corgiman & co.
If some of my posts have across more forthright than they should I apologise..It was not my intention..
i have to dis agree with you im afraid.... if you only touched the boiler and that was not leaking the how can you be riddor reportable if you have not touched the gas fire. They can only nail you IF YOU BREAK THE REGS. I know what you are saying is a bit of good common sense but you don't have to do it.
