Gas meter, to move or not to move?
8 Oct 2011
My Gas meter is currently sited against my exterior single block lean-to.
This will be demolished and a new extension built in its place.
As far as moving it goes (and we all want avoid those extortionate costs) is it acceptable for a builder to carefully demolish the current wall and rebuild the new blockwork in its place?
Would this be classed as a move? I willl look further into it but wanted some initial guidance first before I contact my supplier.
Maybe I could just get it disconnected while the works are carried out?
if your meter will be sited in the same place as before , then its not a move you need to pay your supplier to do
you do need an RGI if you want to remove the meter and make safe the supply whilst you do your work in this area and this is what id suggest that you do
im sure some will say you can prop it up and not even bother , just be careful , but...if the pipework or joints are weak or even worse , pipe only just inside soldered joint....it can just fall out at anytime , even more so now its in slightly new position and pipework under new stress
if your RGI inspects your meter and pipework and can provide adequate support for it and pipework whilst there is no wall then it is ok to have it on
if you damage the supply pipe to your meter, or need it moving, or at any time suspect a leak from here , you will have to call your supplier
Chris
