C
chrissib
After buying a manual on disk, thought it would hold all the answers to this problem, but still dont know what the problem is. Appreciate any suggestions.
Boiler switches on, goes through all the self tests, and will work normally some of the time, but then the safety lockout light comes on and the boiler shuts down indescriminatly. Sometimes when DHW is run and sometimes when heating is on, or both. Always when running a bath.
The system has 4 'Concept' radiators, which appear to have self bleeding keys but the radiators are hot at the bottom and cold at the top in the 3 rads upstairs. The rad downstairs is hot throughout. The pressure guage on the front of the boiler, barely rises off zero, and I suspect this may be the problem. The boiler may be detecting low pressure. But I cant get this pressure up. I have turned on the filler tap at the back of the boiler, and turned the bleed nozzle on the drain return, and there is no air, just water.
I have checked the electics as shown in the manual, and all appears to be in order. I wondered about the pump, but the fact that the hot water is getting to the upstairs rads, suggests to me this is working ok.
Dont want to spend a fortune on plumbers.
Any ideas please.
Any ideas please.
