sime10 said:The good thing is you haven't drowned in a cold bath and the other bit is your fin divertor is f***** ed
paul993 said:AHA !!!
Now then this saucer shaped thingy ... on the neck of it does it have a few stubby screws that are sort of half screwed in ??
paul993 said:and lets say .... hypothetically of course.... that some idiot wondered why those screws were half out, and got the biggest screwdriver he could lay his hands on...... and soft of "tightened" them a bit.........well quite a lot actually........what would that do
sime10 said:Nothing it is knackered anyway
Ok ... cheers Sime...(phew
So .... can someone confirm that swapping the thermistors over wouldn't cause any problems ( same part number according to halstead ...both measured at 10K)
Also, If I take this diaphragm apart will I need any rubber rings /copper washers etc...... or do you normally just replace the whole thing ?
Also these little pipes .... when you say O rings, are they what I call olives ? Or are they rubber ?
Any idea how mech a new divertor / diaphragm / what av u costs ?
