We have a 9.5kw Triton shower. I have run a 10mm cable from the CU to an isolation switch outside the bathroom (12 meters) and a 16mm cable from isolation switch to the shower (further 3 meters). Using shower for 10 minutes then no problem, but longer than that and the 10mm cable gets very hot and the isolation switch also gets very hot and starts to smell chemically. Can anyone suggest a course of action to remedy this? Or should just ignore, seems to still work ok?
P.S. yes, I did say 10mm and then 16mm. I ran out of cable!
The cable is running along the top of the skirting in a bit of trunking all the way.
Cheers,
Stuart
Cheers,
Stuart
