Nixt said:I was thinking fernox DS-3
http://www.fernox.com/?cccpage=ds3&sub=6
Or is that a bad idea that will make me glow in the dark?
Chemicals are for flushing the central heating, not sanitary water.
The instructions on the Fernox site imply that it goes in the sanitary water bit of the cylinder?
Fernox said:Connect a funnel to a suitable length of rubber or plastic tubing. The tubing should fit into (or onto) the cylinder feed connection on the inside of the cold water storage tank and the strong acid solution then introduced via the funnel,
