Hi can anyone help I have a glowworm energy plus EP40B energy saver boiler with cylinder and water tanks that I serviced only two weeks ago as I was having problems with my central heating not working although the hot water was ok.
I changed the three way motorized valve as that is what I was told was needed but no it was not that I then found out it was the wirefree receiver at fault so I changed that and the transmitter.
all is working well now but when I went up in the loft I noticed steam comming from the central heating header tank on inspection there was also hot water running from the expansion pipe this happens when I have the hot water is on on its own also when the heating is on on its own and worse when both are on both togeathe the tank does not overflow it stays at the same level no matter how much hot water runs in to it.
Can anyone help thanks. Mike
