I had assumed that was the standard for CUs. Is it new?What did it say "before"? I'm not at all sure that, "before" Amd3, BS7671 required CUs etc. to comply with 61439-3, did it? ...Presumably the same as it did before. Has it been altered?Does anyone know what, if anything BS EN 61439-3 has to say about such matters?
First published in 2011, revised and corrected in 2012.I had assumed that was the standard for CUs. Is it new?
Supersedes 60439-3 1991
What the material is used for, ambient temperature range, possibility of contact with hot surfaces, etc, etc.What exactly do you mean by application here?Depends on the application
More-or-less - it's title is "Low-voltage switchgear and controlgear assemblies. Distribution boards intended to be operated by ordinary persons (DBO)" - £152, or half-price for BSI members! It's predecessor (60439) had much the same title. I haven't got a clue as to what was 'new' in the 2012 version of 61439-3 (as compared with 60439-3).I had assumed that was the standard for CUs.
A requirement to use CUs complying with its predecessor, 60439-3 was in the initial 17th.What did it say "before"? I'm not at all sure that, "before" Amd3, BS7671 required CUs etc. to comply with 61439-3, did it? ...
... but if it did, then (probably unbeknown to most) whatever 'non-combustibity' requirements it contains would surely have applied even before Amd3?
Indeed it did - so I wonder what, if anything, 60439-3 had to say about the combustibility of CU enclosures (and, indeed, what 61439-3 has to say about the matter).A requirement to use CUs complying with its predecessor, 60439-3 was in the initial 17th.
Thanks. What is the "glow-wire test in 10.2.3.3" - 600°, 900° or what?Very little. From IEC 61439-1: ....
Not necessarily. The English language is often ambiguous - does it mean "(abnormal heat) and fire" or "abnormal (heat and fire)". I actually suspect the former. Such ambiguity would obviously not be acceptable in mathematics or computer programming.I like that. It means that they think there is such a thing as normal fire.
There is. In, for example, the gas burner used in the needle flame test for flammability.It means that they think there is such a thing as normal fire.
– 960 °C for parts necessary to retain current-carrying parts in position;Thanks. What is the "glow-wire test in 10.2.3.3" - 600°, 900° or what?Very little. From IEC 61439-1: ....
Kind Regards, John
I would say the latter, and would prefer "abnormal heat or fire" to express the former. When I get a moment I'll see if Mr Gowers has anything to say on the subject.The English language is often ambiguous - does it mean "(abnormal heat) and fire" or "abnormal (heat and fire)". I actually suspect the former.
It is, or BWOTB, just as unacceptable in legislation, regulations and standards.Such ambiguity would obviously not be acceptable in mathematics or computer programming.
Thanks - and I guess therein probably lies the problem. I presume that the enclosure of a CU comes into the third of those categories and that 650° C is not regarded by some (e.g. LFB) as being adequately high. Mind you, as I posted earlier, Hager seem to believe that even a 900° C glow wire test would not be adequate, hence their decision to go with metal.– 960 °C for parts necessary to retain current-carrying parts in position;
– 850 °C for enclosures intended for mounting in hollow walls;
– 650 °C for all other parts, including parts necessary to retain the protective conductor
