Possible Fubar inside.. Ideas.. ?
4 Mar 2008
Hello guys.
I have been converting my loft for a while and have insulated most of it with celtox and created all the partitions for it.
I am not doing the electrics work, it will be carried out by an electrician. However my mates have pointed out that I needed to insulate after the 1st fix had been completed.
Now I am like .. the cables sockets would go under the new floor joints and the lights will simply run up a new studded partition and then spur out.
does any of that make sense?
So are you saying that you have not insulated yet?
It is much easier to install wiring and backboxes prior to insulating.
As there is insulation going to be installed then the electrician should be made aware of this, so derating factors of CSA of cables can be calculated.
Partitions are up and most of the insulation is in.
He knew about the insulation.
so normally if you are bringing the cables from the MCB downstairs upstairs for the sockets would you route the cables to the top area and drop the cables down the partitions or would you go under the floor joists ?
Having a quick read about the cabling it seems if it is insulated area the amount of current the cable can carry is less. I assume thats because of the thermal risk of fire and heat.
Spoke to him.
Said no big problem :D
Waiting on next week for install.
