Indeed - they can be fitted inside 'non-combustible' enclosures. Furthermore, if we ever get any clarification of how 'non-combustible' the material has to be, it's possible that at least some of the plastic CUs around will prove to be compliant, on their own.It will not be non-compliant to fit plastic CUs. Amd 3 does not exclude the use of them.
Kind Regards, John
Quite so.You've got something here. Years ago, all electrical accessories, such as switches and sockets, had to be fitted to a 'non-combustible box'. Now this meant the old wooden switch pattresses couldn't be used, and metal or bakelite or PLASTIC boxes could be used. Plastic boxes were typically dry line boxes or pattresses (or moulded boxes, as is sometimes preferred).
Indeed. Obviously not what it says - which, as has been discussed, is impossible. The requirement is presumably for some degree of 'combustion resistance', and they really should have defined that, ideally with reference to some Standard.So what is non-combustible??
Just for the record, ABS is a thermoplastic, not a thermosetting one, with a 'glass transition point' (it doesn't 'melt' in the normal sense) IIRC of around 100° C.Thermo-setting plastics (like bakelite or ABS) will char, but go out when you take the flame away.
Aren't there a few exceptions though? For instance if the job was planned a while back, etc?
Obviously this is some attempt to shift a load of old stock, did you notice if any of these were drastically reduced at the end of last year?
The old Wylex ones, with a Wooden back come to mind. Did you know a few older Crabtree Boards had wooden backs too?? I had a 2001 catalogue from Crabtree, and it even had a Wooden backed C50 consumer board in it!!!!!
Who knows. As has been said, there cannot be a requirement for NON-combustibility", since that's impossible - so they obviously intended something less than that but, unless/until they tell us, we don't know what criteria they had in mind. As I said, I would imagine that (in response to flak/pressures) this will be at least partially clarified/resolved in the next Amendment/edition.Is there any way all this has been blown out of proportion? There wasn't a specific requirement the consumer units HAD to be METAL. Just non-combustible. So is the rule only referring to, say, consumer units which are partially made of wood?
C50? That's those big black early MCBs from the 1960s, isn't it?
You could some of that as recent as 2001??
