Having never done this before (I have around 1 - 2 cm of cable to play with here - crimping and chok block out of the running now - thanks for the suggestion breezer) I'm a little cautious as to how I can do this correctly. I've had a quick rummage through the search section and 'heatshrink' often comes up in the replies.
I have spare 3 core mains cable (5mm, grey...) I was merely going to join to each core. Had a practice run on old bits of cable, but I think I'm going to struggle pushing the tight sleeving back down over the join. Might it be possible to keep the original sleeves on and tape over the joins...I'm assuming that this is where heatshrink comes in? Would I also need thinner cable to wrap around the existing cores?
The cable is barely poking out of the wall so this is a right feisty job!
Hope someone can help.
Cheers.
Cheers.
