Hi all
Thanks to you guys on here my alarm has been working fine for the past month.
In the past week though I've had two issues which may or may not be connected on my Premier 48 wired system.
- last week at 11pm downstairs only was armed, and the alarm triggered. I checked the logs in Wintex and the room in which the PIR detected motion didn't have anything obvious that could have caused motion, and the PIR is far from the radiator etc. It was very windy that day though, but I doubt this caused any draft.
- last night at the same time 11pm as soon as I pressed Part on the keypad the alarm started sounding (I have it set to quick arm so usually I press Part then Yes). Putting in the code didn't turn it off. I tried putting in the code on another keypad (which was just showing the time etc like normal) and that didn't turn it off either. Same goes when I tried to use the Keypad in Wintex - when I clicked on Keypad icon after connecting it said something like "Panel not ready".
Interestingly the original keypad still showed the message:
"Do yku want to Part arm:
DOWNSTAIRS ONLY"
(I didn't have my glasses on but I'm pretty sure it said said yku and not you - usually it says you obviously!)
I am guessing the two events are just coincidence that they happened at pretty much the same time. I'm more worried about the second one because it was a complete headache turning the sirens off in the middle of the night, so any suggestions would be appreciated!
DOWNSTAIRS ONLY"
