I was considering installing an ATAG, but they wouldn't sell to anyone who wasn't CORGI registered - even if you were getting a reg to install it, thus i opted for the viessmann.
I can echo some of the other comments on here. THe vitodens 100 is useless. Aluminium exchanger and made on a budget. ALso uses 230V controls and is pretty rubbish.
If you are getting a CORGI to instal it for you then why is that a problem?
Surely the Vitodens 100 is a stainless steel heat exchanger???????
Most installers consider 230v controls to be an advantage!
Tony
VITODENS 100
Stainless Steel Heat Exchanger
Some condensing boilers can be prone
to decay, due to the acidic nature of
condensate. Viessmann has developed
a unique, exclusive stainless steel heat
exchanger that is 100% corrosion
resistant.
Made in-house from a coiled tube, the
square profile maximises surface area
for highly efficient heat transfer. The
0.8mm gap allows condensate droplets
to be forced out, but prevents any from
passing into the heat exchanger.
Instead the condensate drains away in a
highly efficient, self-cleaning action.
The result is an exceptionally reliable,
durable boiler that you can depend on.
In fact, since the first Viessmann
condensing boiler was introduced in
1989, not a single boiler has failed as a
result of decay.
