Hi
Having problems with my washing machine and have tried everything I know. It has been stopping mid-cycle and I got an error code 23 which indicates a drain problem. Had this many times with this machine and did all the usual, cleaned the filter - couple of coins bits of plastic etc, checked the impeller all ok there, no issues with drain pipework either.
In fact no problems with draining it at all. Able to run drain program and it pumps and drains fine. However still getting error 23.
Tried running other programs and even turned off the water supply to see if it could pick up that error, but no just 23.
Is it likely to the PCB in which case I suspect it's terminal... this machines had numerous fixes over the years so probably not worth messing with.
Any suggestions greatly appreciated.
Kind regards
Andrew
Kind regards
Andrew
