Hello,
When we had our bathroom fitted the taps went at the other end of the bath from where they used to be. This has resulted in a fair distance of unsupported pipes.
I've notied when the washing machine shuts off, or the toilet finishes filling there is a short vibrating noise. I think this is the sudden change of pressure in the water causing the pipe to bang against the underside of the bath or something.
I took some pictures a while back when the side panel was off, and you can see what I mean.
I'm going to take the panel off at the weekend when I get time, and holding the pipes still when flushing the chain to see if this solves the problem.
If so, I guess the solution is to fix the pipes to something, so here is my question - am I best fixing some battons of the exact height to the floor and then cliping the pipes to them, or can you get some kind of super long clips that will mean I don't have to fix battons?
Thanks for your help.
