P
Phill Peck
Its the Ecomax 828/2e.
Have had nothing but problems. PRV has been changed twice. Gauge always shows at zero. The small heat exchanger has just failed, water spraying everywhere. Have been told the fan has gone due to the spraying.
Have now discovered the guys who installed it have not followed guidelines. PRV pipe goes up. Gas pipe connection is app illegal. Its just been a nightmare.
Ok fair enough I can understand that if you've had a major leak inside it could be time to replace it. Although it sounds totally repairable.
Sounds as though you have some issues with the system though. A prv doesn't fail on its own. The system pressure would have to rise and also be very dirty for the prv to not seal again
